Existing render not perfect
Hassa
Has anyone got any tips of how I can make smooth ext render look like a sand cement render finish? 90% of the exterior is rough like it should be, but due to build works there are smooth areas which look below average, I have been told by a builder friend to use Toupret ext filler and mix it with sand, and advice would be v apprciated. Hassa
you should consider a coloured acrylic 1.5 it will give you an even finish and will not need painting
Yeah, exterior filler and fine sand mix. Skim it on and sponge finish once it's picked up a bit.
Done this with good success a number of times.
