Freerider
alright guys, just couple of questions for you regarding rendering..
its the one thing Ive not a hell of a lot of experience with, laid plenty of scratch coats and patched small areas but not many large areas! (had one phone call for rendering in the last couple of years, so dont get chance to do it you see)
problem is Ive heard so many different ways to lay both scratch and top coat.. do you ALL rule off your scratch coat? as I was never taught to rule off scratch and never heard of it until I worked with another spread recently who does! ( seems pointless to me as the wall should be farely straight if built properly)
and also how do you go about ruling off top coat? both vertically and horizontally? or do some prefere just one way? as ruling both horizontal and vertical seems another pointless thing to me as surely if you rule one way and then go the opposite way you will end up ruining what you already ruled to begin with? (if that makes sense)
I suppose its just strange to me because I was always taught screed method of floating so free hand ruling seems a bodge way of doing things but just something that needs to be done on external as screeds will be seen!
Ive always laid scratch free hand, got it flat as possible, then top coated, ruled off vertically and rubbed up, help is much apreciated though fellas as you all know, we are always learning and always striving to be better! :0
cheers! Ad
cheers! Ad
