mgplastering
Hi guys
was hoping some of you could help with all this talk of these spats etc im now thinking of buying one i think i am going to get the eze spat or the refina any advice as to which one is better? also what is the process wen you use one of these are they good for flattening both coats? do you use them for trowelling up if so do you need water? at the moment i lay 1st coat in with speedskim then go back to trowel to lay in 2nd coat then 2 wet trowels and a dry trowel so i was wondering if with the spat do you lay both coats in with it then do your supposed 1st wet one with it then maybe go back to the trowel for the last one? any advice would be much appreciated.
thanks
thanks
