Ghosts
I can't believe someone actually bought a 2 meter tapeWas measuring it n went to move hand n tada locked onto it
What the tapeHa ha!!! It’s like those magic linky things from a posh Xmas cracker!!
Found a cheap source? Can't justify the price getting non mesh for 70pHate those beads, mini mesh all the way.
Also regularly came misshapedFound a cheap source? Can't justify the price getting non mesh for 70p
True, just preference really. I feel you can get the mesh tighter on to the existing angleTried mesh one never again. Mesh coming away from bead. Probably ok on perfect angles but otherwise misshapes
So where can I but a box?True, just preference really. I feel you can get the mesh tighter on to the existing angle
Better fix for those who stick beads in first coat an good for arches ( one side snipped every inch , stronger than stop end )Tried mesh one never again. Mesh coming away from bead. Probably ok on perfect angles but otherwise misshapes
I always use the plastic beads from Screwfix for arches. Curves reet lovelyBetter fix for those who stick beads in first coat an good for arches ( one side snipped every inch , stronger than stop end )
Cheers, will give them a goI always use the plastic beads from Screwfix for arches. Curves reet lovely
No worries. They're bloody goodCheers, will give them a go
