Ssm robertson
First of all I stripped back some old plaster/browning back tongue brick work as most of it had crumbled away. I also did the same with some old lath plaster. I then used sbr all around the areas that were dry. I left it for about half an hour and then I bonded out the areas that needed repaired. Where the brick work was I was slightly nervous about the depth so I filled it out slightly and then keyed it as if i was first coating sand and cement. My plan is to go back tomorrow give it a quick coat of sbr and then finish off the bonding and then skim over it using 2 coats. There was also some damage to the angle on one of the reveals around the window so I tried My best to form an angle using my trowel as a straight edge and my margin trowel to fill and smooth the angle. Im just looking for some general feed back and tips for the future.
