Fibres
MHLPlaster
Evening chaps, I've gotta small 20m2 rendering job to do in the coming weeks, where's the best place you guys get your fibres for the best price? Yous buy online or at the builders merchant?
cheers lads
still scrim any Joints or Cracks. Just put a small handful of Fibres in your water. Whisk them around then add your pooder
First coat only. Although you cant see them anyway so dont know why you couldn't put them in top coat. They may appear more once the skim is compressed and trowelled
If you are over skimming and there are the odd hairline cracks on walls for example,do you not scrim them but instead use the fibres in the mix. I assume first coat only then skim on its own for the top coat?
I still scrim any bad cracks but dont bother with the hairline ones. Not bulletproof though, if the wall wants to crack it'll crack, Just gives a bit more protection.
£3. Dont know if theyre cheaper from that website but its handy if youre caught short and need some asap
