filling over new plaster
chief09
Hello,
I'm up against a bit of a deadline to get a room finished and painted.
My plasterer is telling me he will finish the plastering tonight, I should then fill any bits that aren't smooth and do a mist coat in the morning then he will come back and sand the bits I've filled tomorrow afternoon. then I can continue pianting this weekend.
Can I fill over new plaster? If so what should I use easyfill or caulk?
Also I have paint for new plaster which I understand is what I need to allow the walls to breathe, but will that be OK to use even if the plaster is still pink? Finally if the paint is OK, should I water it down - it doesn't say that on the tin, but I'm not clear for the first coat.
Many thanks
Hello,
Many thanks
He’s not a plasterer
@chief09 he shouldn’t be expecting to leave anything that’s needs filling if he is then it’s highly likely he doesn’t know what he’s doing. If I were you I’d get someone else in quick. Where abouts are you based? Someone off here may be able to help you out.
Hello,
Many thanks
Is his name ANDY, quite tall, slim, very OCD ,only has one 2 hr break ?
Hello,
Many thanks
Should t be doing any filling over new Work
Why should you need to fill anything? The job should be finished ready for you to paint. Contract Matt for mist coat should have about 20% water added.
Hello,
Many thanks
is this a joke?
Bet was a cheap price cos any decent Plasterer wouldn’t be saying to use easi fill
John is richer than super spread I wouldn’t mind better they could keep a small country running with doe they got
Thanks, unfortunately he's almost finished, so I'm just trying to minimise the problems at this point.
Thanks. He's already done some, should I tell him to take it off?! So I guess all I can do at this point is mist coat then get him to sand anything thatt doesn't look right. Does that sound about right?
U have paid for a finish ready for painting not to be filled before you do can always get the odd bit but not what your saying needs to be done it’s on there now so leave and rub down I just hope for your sake it’s been put on nice and flat and easy to rub down I wouldn’t of easi filled before I miss Coated anyway always get a miss coat on then fill don’t paint over the filler already on Plaster is my advice to you also
Thanks for the advice - sorry just to be sure I understand- are you saying don't paint over the bits that have been filed?
I wouldn’t rub them down first then paint over then paint over it then see what you got from there filling wise otherwise your have to rub the paint back over the non rubbed down filler which will be a pain
So rub down what’s on wall already
Paint
See what you got
Fill
Then rub down
Then paint away
To be honest think you have been had over really with all this filling
Can we have some pictures of his plastering please and your bum x
Paint
See what you got
Fill
Then rub down
Then paint away
Ok - Thanks very much for the advice!
