finishing spatulas
mickey07
Hi chaps,got myself one today from refina, 22 inch.Thought id invest in one for the ceilings,anyway just want to know the pro's and con's with them,plus does anyone use them for finishing walls as well???as im just thinking are they mainly for ceiling work...p.s. took your advice from here on a plastic trowel from bartons and love it...cheers chaps..
No mate,its just says a "finishing spatula" for plaster,got it from refina,its got a black handle and very thin blade...(sounds the same as what your on about)
There slightly different mickey both do the job though, I used the super flex spat for flattening in I couldn't do anything else with it tbh just tore, didn't see them myself but apparently a gang working next door were troweling up with a spat and there finish was mint if you've got the spat with two holes either side of the handle you can get an offset pole that helps you reach ceilings
it has got two holes on the handle spunky,just above the part where you grip it mate....where can i get a pole from then bud?
Link Removed
I think these are them mate I hope that poles telescopic or it's all a bit pointless I'd ring them first
