Yep, bought a cheap Chinese 1800w mixer £58 hopefully ok. Can’t see the point spending loads.cheersEbay cheap Chinese £45 1600w two gears
Had mine for years , get spare motor brushes , keep them in the vanYep, bought a cheap Chinese 1800w mixer £58 hopefully ok. Can’t see the point spending loads.cheers
I take it you mix up half a bag at a time?Yep, bought a cheap Chinese 1800w mixer £58 hopefully ok. Can’t see the point spending loads.cheers
Mine mixer adhesive all day no problemI take it you mix up half a bag at a time?
I can’t see it mate. The cheap ones either slow down after a while or burn out. Can it mix up 3/4 bags of stick at a time?Mine mixer adhesive all day no problem
Why would I mix up that much , on me own , 1 bag mix , just empty on board , water in , dust in 10 min before I need it , easier to mix as wellI can’t see it mate. The cheap ones either slow down after a while or burn out. Can it mix up 3/4 bags of stick at a time?
And back and tri.s and shoulders and legs lolPiece of wood
Good for the biceps
Red crossYep, bought a cheap Chinese 1800w mixer £58 hopefully ok. Can’t see the point spending loads.cheers
Haha once on a job and had a power cut just as i was mixing second coat . All i had was a two foot lengh of 3x2.And glutes lol
Front bike cog welded on metal tubeHaha once on a job and had a power cut just as i was mixing second coat . All i had was a two foot lengh of 3x2.
Old boy on a job once said them mixers are good . Do you have the old style hand mixers . I said no . He said what if that breaks . I said i go home order one on internet and come back when its been delivered
Why not? Are you a diyer? Oh I know why not because you and your puny mixer would be blowing out your arses! Hahahahaha!Why would I mix up that much , on me own , 1 bag mix , just empty on board , water in , dust in 10 min before I need it , easier to mix as well
Hopefully. What if it doesn’t workYep, bought a cheap Chinese 1800w mixer £58 hopefully ok. Can’t see the point spending loads.cheers
popcornI take it you mix up half a bag at a time?
OmslWhy not? Are you a diyer? Oh I know why not because you and your puny mixer would be blowing out your arses! Hahahahaha!
Ha ha , just depends on how you plaster , "all the gear "Why not? Are you a diyer? Oh I know why not because you and your puny mixer would be blowing out your arses! Hahahahaha!
