;DSkyZOO said:sand & cement.......lol
SkyZOO said:so im guessing if i use sand & cement its best to cut back the beads before in goes off.
also wondering is it ok to use different backing plasters on the same wall. lets say scratch with sand and cement and finish with hardwall.... or S&C scratch with waterproofer in the mix then finsh with pva and bonding plaster. cheers
I cut back when im rubbing up. You dont need to use another plaster on sand and cement you should get it with that but if you do, bonding is best, dot and dabbing on S&C is done as a parge coat between two houses usuallySkyZOO said:or is it just a stupid question....... ive heard of people using a waterproof scratch coats then dot&dab before. do many people use this method. cheers
essexandy said:I rule of the beads and then when putting the float over the wall I scratch it up nice and neat and tidy and then rather than actually cutting back from the beads as some do I run the float down the bead at an angle which takes the S&C back from the edge just enough to allow for the skim.
spunky said:i dont rule of beads unless i have to .......dub the rest out with skimming
carlos said:as above float to the beads and cut back. Didn't think there was any other way!
spunky said:why not rule inside of the beads
