S a plastering
Can anyone recommend a decent float for sand an cement finish broke mine in the van other day got a couple of external float finishes coming up cheers
Emir green big and emir small hard for second float.
Sent from my HUAWEI G6-L11 using Tapatalk
I know it's a poly float mate just wanted to see if there is any other options like the diamond faced onesPoly float?
Dairygold co-op Mogeely Co Cork. But have seen on line. They are harder than the gypsum ones and last a good bit longer, though with that take a bit longer to break in. The small ones are great for second floating break in much quicker than mahogany which are lovely also.Where did you get yours from paddy?
Just gave mine to a builder I do work for do concreting, had it sanded down for use, but found it to smooth going over s&c, seemed to slide over everything instead of cutting through the gear if that makes sense. Had to wait until the gear was a lot harder than normal to use it too as it stuck everywhere.Dairygold co-op Mogeely Co Cork. But have seen on line. They are harder than the gypsum ones and last a good bit longer, though with that take a bit longer to break in. The small ones are great for second floating break in much quicker than mahogany which are lovely also.
SorrrrryyyyyI know it's a poly float mate just wanted to see if there is any other options like the diamond faced ones
How are you ruling it K? With S&C I give it loads of lath preferably a good straight 1x1.5 maybe 4ft long, first up and down and then lightly across always with a light sawing action of lath. I find concreting doesn't get them how I like, also if you find too smooth pull them across the edge of a saw few times, though have not had go do very often. Oh not your nice saw by the way.Just gave mine to a builder I do work for do concreting, had it sanded down for use, but found it to smooth going over s&c, seemed to slide over everything instead of cutting through the gear if that makes sense. Had to wait until the gear was a lot harder than normal to use it too as it stuck everywhere.
Worst float I ever bought.
Diamond float is ok
It wasn't a dig at you big mardy arseSorrrrryyyyy
