My entire house is flat roofed and ive had it re covered and insulated making it a cold roof.
I 6am going to pull down the old lath and plaster ceilings and replace with plasterboard, whilst doing this i need to install a vapour barrier, which for most areas i will cover with polythene, however the joists about the bathroom were in bad shape and needed to be replaced so i wana use foil backed plasterboard for this room as well, just wanted to know about sealing the joints. Is using foil tape ok or would it cause a problem when skimming over it.
