Forgot the cement :(
FreeD
Hi all
Was doing a sand and cement float coat today on a bathroom and have an awful feeling that i forgot to put cement in the final mix.
Is there anyway of telling tmw when i go back to skim? colour? texture? etc
If so whats the best course of action just to take the patch off and rerender?
The patch is middle wall...is going to be skimmed then ceramic tiles 150 x 150
Is there anyway at mixing stage also to tell if cement has not been added?
Think i'm going to have to right cement on the back of my trowel to remember!
such a tiring day i'll be gutted if i did forget :'(
i take it you were using lime as well or are you saying you may have forgetten to put cement in and ended up with neat sand an water..and couldnt tell???
well if youre serious..and there was no cement left in the bottom of the mixer from the last mix..it'll erm... be on the floor tomorrow..
just scrape it up, throw it back in the mixer and add some cement..
p.s. you dont need to skim it if youre gonna tile it....in fact as long as you got a reasonably flat finish on it its prolly best not to...
youll only have to pva the skim before you tile it..
what ratios were u using? cos if youve done it right..believe me you'd know, while it was sloshing arond in the bottom of the mixer looking like wet shite...
trust me if you go back tomoz you will now if theres no cement in it when you scrape it down,best take a bag of hardwall with you
