garden walls
S a plastering
been asked to render smooth 120m of big garden walls been to see them an brickwork aint clever also diff bricks mixed in was going to weber ocr the lot the question is would weber be ok with just mesh in or rendid the lot with mesh into that or rendaid then tight coat of ocr with mesh then top off cheers
If it were one brick no cracks and sturdy you could go straight over it without mesh or mesh the joints on the different bricks only with a wide overlap you're shout mate
parex microgobetis is great for evening out suction, creating a mech key and is piss easy to roller on. Tis the outside equivalent of pregrit. could use ocr like mono in two passes with mesh in the first. Better still get hold of some CPI and save the dosh
Work your options and costs out and give them to the customer and let them make the decision, dont lose the job by going over the top its just a garden wall.
use s/c cheaper then mono ffs scrach coat it bed in mono mesh then top it off
yer the mesh is £50 a roll but what you dont use you can sell too me init m8 :RpS_thumbup:
