Gummier fat recipie??
Ky12
Hi guys, I'm getting through the process ok and happy with the finish. However.
Occasionally I look at the finished wall and it looks good....then a few hours later small patches imperfections blemishes etc appear as if when filling them with fat it's too runny and trickled away if that makes sense?
Any suggestions??
Cheers man, I had wondered that. Out of interest then, what is it about a thin coat that causes this?
i don't ever fill with fat... I always leave small amount on the spot board/ligger for filling :-)
Some days however you will leave a surface perfect and the following day you will walk in and think how the feck did I miss that......
All the filling should be done before you get to the 'fat' stage,it would be worth doing what danny says and save a bit of gear or make your sets smaller and more manageable:RpS_thumbup:
Great advice! When leaving a bit on the spot board, can I keep adding and working water into it to keep it gooey? Or just get all the filling done as kgre says
