hacking off old houses
richardbrown
f.king hate it ..... all the reveals and heads are f**k*d the render is about 2.5" thick
can do without it to be honest
dont forget to get the washing in ;)
i got 2 5kg makita breakers.
There is so much scope for f**k ups on these jobs .... as i said all the lintels are rotten the reveals have crumbled to bits etc etc
spent the day pulling my hair out
is it down to you rich to fix lintels? and would you fix them your self ie prop up and slap in concrete replacement?
why do bombs need big clocks? And why do they always make a beeping noise so they can be found 2 seconds before it goes BANG
I bought a makita breaker for 200 notes on a recommendation on here and I might as well have used my electric toothbrush to hack off with :'( Great for tiles etc but hard render, forget it. Hired a couple of bosch hammers, piece of cake
Big clocks are easier to wind up and the buzzer is so you know to put your fingers in your ears, everyone knows that :D :D
what model was the makita goodyson?
not the hk1800?
richardbrown said:
no the lintels are an extra but most victorian houses will need them replacing so bear it in mind
The one I am doing rich that i was tellin u about is having all the lintels replaced but that was the customers intention from the off.
What system u going back on with? Ie, pre treatment/base/finish etc? is it mono
something iv not come across yet mate but is replacing lintels much work? is it a case of supporting bricks,blocks above and replacing and mucking in?
then making good on the inside!
Its not something I would do pal I would sub it off to a good builder but get the client to sort them out directly unless they really wanted an all in package.
Did you get the PM
are dads a builder mate just trying to understand the work involved so if it crops up i can see the costs involved. yup just sent one bk 2!
not the hk1800?
yep that's the one....a good tool to have around for the odd job especially taking off old black mortar and tiles internally but external hard cement render.....um no. have you got one then?
out of intrest how deep into the year will you take on exterior rendering work on ie October November?
richardbrown said:
cant render in the rain boyo ..... i got a biggish job on the way so ill get the riggers to tarp it out
Used to do loft conversions and the scaff company rented them riggers out by the day or week if my memory serves me correctly is that the case for all or most scaff firms?
goody said:
not the hk1800?
Nope but nearly bought one due to a recomendation on here, but now I will opt for a bosch maybe
Its normally ok up until the xmas break than after new yr we try not to do any rendering in jan and feb But this yr was so bad we were nearly in april before we were up and running.
lost a big job because of it due to the programme being a febuary the 25th completion? I asked them who in construction dreamt that schedule for rendering works? they thought i was being sarky an give the job to someone else So I said 'your not interested in quality then' needles to say we have not heard from them again. but you remember in feb there was 10 inches of snow on the ground
I looked a a barn conv last month that was rendered this winter and the whole thing needs hacking off and starting again that will cost him thoushands
Remember this
it's the one started by a builder a couple of years ago, and we was asked to put it right, well we told him we wouldn't work sort of nov to feb on externals , but the guy was desperate to get it done , so we started it at the back end off Nov , started by clearing all the (german word) he had left (4 skips) started snowing a week later , and we ended going back in March this year to finish it.
Been trying to get back to take some photo's on a nice sunny day , but been too busy
We did the drive also , cos he was so concerned about gettin another builder in
oasis said:
what the brown lines at top is that painted on or made of render or si it just timber?
They are plastic cladding strips, he wanted the house to look how it did originally and decided to tell us this after we had finished fitting the new soffits, fascia and rendered it, or we could off just incorporated the feature in the render !!
The whole house is pissed Rich , the previous builder re built the front gable and made a right b*ll***s off it ,also the stack on the right was re built and it was nearly two inches outa plumb over 7' all the windows are in pissed, we had a night mare on this job.
some of the s**t left by the previous guy
There's too many issues/pictures to post
