RemovedUser
i know you guys can spray pral m and archive a rough cast finish sprayed.
but can you use a tyrolean gun to flick spray pral m?????
and can you apply pral m over old painted render if cleaned off and blown patches removed?
if soo will I need a primer sbr slurry???
My first forts was to clean off flaky paint hack off blown render
wet the wall with water or PVA build up the patchwork/
then flick one a coat of pral m trowel in to push it on then bed in mesh maybe
then flick on top coat finished
or just clean off the wall then sbr slurry coat then tyrolean gun pral m over the top finished
