I would have gone for BG render for dpc work , the fact he has put vandex on why hardwall would not be my choice. What is it going over block, brick , groundfloor, first floor.
hardwall is not for low suction backings, i wouldnt as i think you will have problems. I would do what henry said. personally i would give it a spatter coat with sand cement and spr to form a good key and then sand and cement.
i said to him use limelite.at the end of the day,you can only mention it them(builders),it`s his job,so any comebacks is on there heads.9 times out of ten they won`t listen.
