hardwall
eddie
has anyone used this after a chemical dpc?the firm i do work for is thinking of it and having used limelite for years im not to sure,HELP
Something I allways thought.
If they are installing a dampcourse and they are saying this works why do they go on to specify waterproof plaster?
Seems to me they arn't that confdent their product works.
its not really a waterproof plaster,it allows the brick/stone to breath and let any moisture out along with salts
Sand and cement with waterproofer is, as the name sugests, waterproof mate.
I'm not talking about the spec you have on this particular job I'm on about normal jobs.
even after a dpc injection the wall doesnt just dry out overnight... it takes months...
so by using hardwall your not goin to stop the residual moisture being drawn into the room....
if they want to cut costs, tell em to buy a belle mixer, sling a ton of sand on the back of a transit, drop a ground sheet down and mix it on the road behind the van.... 3:1 sand cement, plenty waterproofer...
make sure the waterproofer has a 'salt neutraliser / repellant' in it or youll get salts forming on the inside....
render with waterproofer in isnt 100% waterproof or you wouldnt need a salt neutraliser...
but you do, so it isnt, its just highly resistant to the passage of moisture, not completely, just very good at it...
you also shouldnt paint the wall with any kind of waterproof paint for a good year afterwards...
or youll have problems...
all this is assuming the diagnosis was correct in the first place, moisture WAS actually present in the wall etc...
if theyre just ripping people off telling em theyve got damp when they havent you can use bonding if you like or just dot and dab em.. ;D
any gypsum based material no good after dpc injection
stay with limelite or s/c with waterproofer added
had a few problems using s/c with SIKA w/proofer recently. Re did it
using SOVEIRGN w/proofer and it sorted the problems with efflorescence
I've got a job to do as above, dpc done and replastered with hardwall two months ago, it's still hanging wet with salts starting to show, chop off and redo with s&c!
