If the cracks are on the board joints then it can only be movemet from the boards.Agreed the scrim nowdays isnt the best but must be something you doe whilst putting the boards on
Like suggested you probably
A) Not put enough adhesive on so the boards have moved slightly
B) Put to much adhesive on,so when drying out the boards have slipped very slightly
C) You did not allow enough time for boards set before removing packers under boards and skimming
D) Maybe the boarding wasnt great to start with i.e gaps to big between them ?
E) Are you sure you scrimmed all the joints ?Also bed the scrim in with a tight coat of plaster i beleive this helps to stop the cracks also it gives a visual mark of the joints and makes a missed joint more noticable.I always run a tight coat over scrim on my ceilings,walls also i i have enough to go at.
D)
