I'd like to insulate my concrete garage and I'm not sure if I need more insulation?
Internally I plan to:
1. Paint the concrete slabs and roof with anti condensation concrete paint
2. Use DIY spray foam insulation kit on the ceiling and walls
( Link Removed )
3. Fit plyboard
4. Fit sound resistant plasterboard
I will be fitting a vent in the garage door as I have been told that's a good thing to do to prevent moisture build up.
I will then enter the building through the door on the side of the garage (not show in pic).
Will this be enough to keep in the heat that the 2.5kw Air Con unit will provide or should I add another insulting layer?
I have read amazing helpful tips on here and I'd like some more advice on this job please.
Thank you
( Link Removed )
3. Fit plyboard
Thank you
