DI5plaster
I have an old solid wall sandstone barn / cottage (approx. 150 - 200 years old), I am having the dining room plastered however there is rising damp on the external walls and around the fireplace. The old plaster is onto a cement rendered wall with bitumen damp proofing however this has failed over time.
I am going to use damp injection cream on the exterior and hack off the existing cement render, tank it then replace with dot and dab plasterboard. Is there anything more / else i should do?
Thank you!
Thank you!
