Hi guys
Needing some professional help please.
Have a wall that’s had water damage but found the cause (not damp) lots of salts bleeding through plaster.
I’ve taken the walls back to brick, do I need to stabilise the brick with a salt neutraliser before re-plastering?
Also would you recommend sand and cement as a backing coat or can hardwall be used?
Thank you in advance
