Help - trying to work out how to repair around an old fireplace
Jezzer
Hi - I'm new to plastering although have done a bit of lime rendering. I'm renovating an old fireplace in our home (ripped out a 60s fireplace and opened up inglenook; going to fit an oak beam (with suitable heat protection) and wood burner. I'm going to render most of the brickwork (some old soft bricks, some new) with lime-based Fibrechalk from Anglia Lime https://www.anglialime.com/products/wet-mix-plasters-angliamix-mortars-renders/fibrechalk. Most of the job is under control but I'm trying to work out what to do to repair the cement mortar that was slapped around the sides of the fireplace back in the 60s. I'd like to patch and skim over it with Fibrechalk but I'm not sure whether it will stick to the old emulsion paint that's been applied to most of it.
See photo. I'm talking about the yellow painted bit on the left. This used to be the inside of a cupboard that was fitted alongside the chimney breast.
Questions:-
- Should I scratch it first (hard work)?
- Would a coat of PVA be enough to bond the render to the old wall?
- Any other tips/ideas?
Many thanks in anticipation! :D
Jez
Will grit work on render. I thought it was for skim?
Personally, whenever I've had anything like that, I've put a key in it with the whizzer.
Not sure what the OP thinks is hard about that?
Link Removed
blue grit will be fine with render internally.
there's waterproof grit as well for render for external work......Rendagrip.
Hi - I'm new to plastering although have done a bit of lime rendering. I'm renovating an old fireplace in our home (ripped out a 60s fireplace and opened up inglenook; going to fit an oak beam (with suitable heat protection) and wood burner. I'm going to render most of the brickwork (some old soft bricks, some new) with lime-based Fibrechalk from Anglia Lime. Most of the job is under control but I'm trying to work out what to do to repair the cement mortar that was slapped around the sides of the fireplace back in the 60s. I'd like to patch and skim over it with Fibrechalk but I'm not sure whether it will stick to the old emulsion paint that's been applied to most of it.
Questions:-
- Should I scratch it first (hard work) fireplace repair in vaughan?
View attachment 27991View attachment 27991
Jez
Hi there.... How do i go about repairing the inside (base) of a brick fireplace. The brick/mortar has fallen out over the years. Do i just use normal mortar and brick up the hole in the base? Do i put a layer of sand down then a layer of mortar over the brick base? Thanks
Concrete to pack it then sand and cement.
