Help
Hoboman68
Hello there and I got a question that I can't se to find through research. Here it is I believe u need to install some sort of baseboard if I am using metal lath, do I need a baseboard?
Is a backboars that gows behid the metal lath needes, that way the plaster would have a stoping point or if it would it be fine just hanging the mate lath without a backboard?
I thought baseboard was the Yank term for skirting?
a tight breathable membrane behind the lath would be enough. are you rendering ?? as might need to counterbatton on top of the baseboard
