Hi, can any one help.
Mark collier
I have just had my house rendered with parex monochouce, I can now see my block work called ghosting. Would coating it with parex Paraguard stop this.
Don't put paraguard on it as you need to put more render in and I wouldn't fancy rendering over paraguard
paraguard is a clear protection coat from.the weather elements.
1stly i would check you havent got any water ingress getting to the blockwork.
ghosting blockwork.joints are usually caused by render applied over damp blockwork in 1 coat.
do you know what blockwork.was used?
We have used 7 newton blocks. Will it dry out overtime or is it always there.
I was hoping the paraguard might be a damp repellent
It is a new build so there should be no damp issues. It was only done just over a week ago, do you think it needs more time to dry ?
It could have been put on too thin if the blockwork joints are showing through.
An equalising paint will cure it. Or try Parex colour wash.
