all
Just looking for some advice or ideas to cover up the attached picture situation please.
Log/coal fire my mum had didn't have flexible flue installed so soot build up in chimney only discovered after painting walls. Getting flue installed now etc but the stains will continue to come through unless I do something like the title I think?
Have sanded whole room and it kind of disappeared for now but will come back with any water based products applied I've read/heard.
Read many many ideas and definitely ain't trying the cow dung method sorry!!
Just want to build over a new wall to hide it as it seems easier/quicker/relatively permanent solution to rectify?
Don't like the stain block paints, not a smooth finish feels like sandpaper been wallpapered on there unless others know different?
Basically looking to lining paper the whole room then paint it. It's all internal walls backing onto chimney stack.
Was going to batten upto ceiling height and maybe across the ceiling level and floor and between battens at 300mm horizontally (not sure if horizontals necessary?) then plywood over battens for some strength if anything needs to be screwed on the wall, then plasterboard over, then lining paper it all. Does that work/seem OK? doing battens for air circulation etc?
Any advice greatly received on idea/batten sizes/amounts of/plywood depth/plasterboard type used?
Any questions you have I will answer as best as an electrician can!
Many thanks all for any assistance you give
