Hose Lubrication
sparcraft73
Dear forum members,
what type of lubrication should you use to prepare transport hoses for cement-based plastering? I use water to prepare pump and hoses but can you use any other lubrication to make the transport of the plastering with less friction?
/sparcraft73
As PFTWales said wall paper paste or plenty of Fairy liquid. Find the more expensive washing up liquid is better than the cheap stuff. More froth the better.
You can get a silicone powder which you mix with water and flush through your pipes and worm . Only cost £4 per sachet which will do 2 flushes . This doest have to be done every time , maybe every 5 - 8 sprays.its supposed to make your worm last longer aswell
Where can I get it?
