AV seen people use the top coat to scratch with I have only used base coat is there any advantage in using the top coat for the first scratch coat ?No problem doing that by hand. I've finished 70 + by hand and am not the quickest. Just have the right set up. If you can get a machine in. Better finish
I've never used the top coat as a scratch.AV seen people use the top coat to scratch with I have only used base coat is there any advantage in using the top coat for the first scratch coat ?
2 hours to hand apply 140m2?70 not bad I did 140 once only took couple of hours don't know why people bother with machines
