How do you fit a geka fitting to a water but?
I had a 3/4 inch bsp tank fitting from my old tank in the loft and then ordered a 3/4 inch female Geka fitting. Done the same on the inlet but with a float valve.
Haven't used it mind. Thought I'd get away with not using a water pump but that didn't happen.
Nice one what did you go for? If you're in Glasgow with it give me a shout I'd be interested to have a wee nosey seeing it work if that's alright?
you got jobs lined up? I've thought about a machine but I just don't think we would use it often enough to warrant the lay out.
Bought a strata from Enewall, got it for a good price so just going to preserve with it and see how I get on. Got two houses stripped ready to go and a few other things once weather picks up. I'll give you a shout once I think I know what I'm doing.
Show off
:popcorn:
No drained a header tank the other week and fitted one to supply a shower. Emptied the tank and drilled a hole and fitted it in two minutes, unfortunately I forgot to remove my dewalt when I filled the tank up :(
Phewww...thought for a minute there you were going to say ..Yes.
Agreed
I bet you a £20 note he can
I got a 14" I bet I could as well.
:rebotando:
Speed ain't everything, you have to make time for life's most important things like coffee breaks f**k**g around with other trades and whistling at bypassing ladies
And wanking.......don't ever forget that(y)
Cant believe weve lost anothet good man to the darkside:crying:
dont hear much about strata... good or bad... will be interesting to hear your thoughts :D
Iv got to do hpx with full mesh and k1. Bout 80m2.
Think I'll do hpx by hand.
Got to do it with a water pump n butt aswell cos the tap there is complete s**t.
Have u got a new r&s??
