How long can I leave hardwall plaster before multifinish?
Jimbobjam
I want to do all the hardwall plastering on my build prior to doing most of the stud work and boarding elsewhere. It would mean leaving the hardwall for up to a month before I multi-finish. It is wise leaving the hardwall this long? I would apply pva or bluegrit prior to the finish plaster.
You want some of this dark grey polish plaster for hardwall that's been there ages
I wouldnt recommend leaving it for a month it will suck like Monica lewinsky,ive always skimmed it the same day on occasions skimmed the following day and your going like the f**k**g clappers
Do all your stud work then board it, skim it, then float and skim same day. As it should be done
Your going to come unstuck pal leaving it a month put enough on in the morning which wont be hard your clearly a diy er then turn back an skim it in afternoon
