Not workingNew system to fix plaster/render beads
Still didn’t work must be my phonepress video icon and wait to load then press play.
on solid plaster?Good luck to you but I don't think it will take off looks like a lot of faffing around I could of nailed that quicker than to bead taped it
After a while you learn to grip them hard when pulling out the box, that was the main time I got cut when pulling them out and they catch and your hand slides down themI liked the idea behind hook ons but they are deadly if you catch them. Good idea on paper this tape but don't think it's any quicker tbh
That's how I got caught tooAfter a while you learn to grip them hard when pulling out the box, that was the main time I got cut when pulling them out and they catch and your hand slides down them
Just remember when your ready to pull out grip it hardThat's how I got caught too
Well if it's on solid you generally gotta glue walls so knocking a bit of drywall or skim don't matter as your waiting anyway!on solid plaster?
Also a lot of overskim work walls are s**t anyway so if anything is kicking out you can adjust to suit when sticking beads! Hands down the right and best way.Well if it's on solid you generally gotta glue walls so knocking a bit of drywall or skim don't matter as your waiting anyway!
Glad to hear it bud, nice trowel that one.im glad it's good use to youStill using your nela by the way when I skim, its turned into a lovely trowel
I use it as little as I can possibly get away with....but it is a good un when I need itGlad to hear it bud, nice trowel that one.im glad it's good use to you
s*x tips now.Just remember when your ready to pull out grip it hard
Right... I'm going to say something I didn't think I'd say as I've given you alot of s**t for it. I actually quite like it, you should of started with that video straight away though. IF British gypsum approved the tape that plaster stuck to it, I'd probably use it on dot and dabbed walls where it's hit and miss if you can get a fixing, and on solid wallsNew system to fix plaster/render beads
my tape wont cut yer hands!I liked the idea behind hook ons but they are deadly if you catch them. Good idea on paper this tape but don't think it's any quicker tbh
You could stick beads with drywall PVA and have a McDonald's come back and get skimming! Don't see your pointyou could bead up first PVA
you could bead up first, PVA over tape and have a cuppa with the news paper while glue firms up.
your right.You could stick beads with drywall PVA and have a McDonald's come back and get skimming! Don't see your point
stop flogging it its deed
i will be in touch with British gypsum soon then.Right... I'm going to say something I didn't think I'd say as I've given you alot of s**t for it. I actually quite like it, you should of started with that video straight away though. IF British gypsum approved the tape that plaster stuck to it, I'd probably use it on dot and dabbed walls where it's hit and miss if you can get a fixing, and on solid walls
I hope it takes off for you fella if it hits the sites you will be quids in so fingers crossed for you! I sincerely wish you all the best with it just takes one foot in the door with the right people I supposeyour right.
what u drinking lolI hope it takes off for you fella if it hits the sites you will be quids in so fingers crossed for you! I sincerely wish you all the best with it just takes one foot in the door with the right people I suppose
thanks smoothI hope it takes off for you fella if it hits the sites you will be quids in so fingers crossed for you! I sincerely wish you all the best with it just takes one foot in the door with the right people I suppose
i will be in touch with British gypsum soon then unless they get beaten to it.
I've decided to be nice today IL be back to my cuntish self tomorrowwhat u drinking lol
thank f**kI've decided to be nice today IL be back to my cuntish self tomorrow
