I have had my home rendered using a coloured render and then scratched.
mr ab
some areas have dark circle and under the windows have white v shapes.
Is this common and what is the solution.
It was rendered and scratched last Thursday and I though it was just drying out.
There are lots of areas that don't match.
I chose a light grey colour.
Does this mean it needs painting?
It was all done in 1 coat.
I can't remember what brand was used but it was trowelled on to brickwork.
Do you think it needs longer to dry.
Since thursday It has been so warm I am worried it won't change.
Will it need painting as another coat may not be possible due to maxed to the beads.
Any advice appreaciated.
Guess you mean I have been ripped off?
Good thing is I still have a tower scaffold, how much can I sell that for?
If it's reasonably flat it can be gone over with a thin coat system, or if you do paint it your going to need a compatible paint for mono renders!just depends on what you want to go with! But paint won't hide the flat spots so easy!!
I’m in Leicester this week mate but have no comment for this op, could be so many scenarios I refrain from pointing any blame to any plasterers
