insulated plasterboard
Can anyone tell me the best place to get hold of some insulated backed plasterboard? I only need about 6 sheets of 8x4 with 12.5mm board and 25mm celotex or similar stuck to the back but really struggling to find any on line that doesn't charge stupid money for it.
May just end up battening out and celotexing if I can't find any
Cheers all
Not sure where your based. But try either Minster.....Sheffeild Insulations......Encon or CCF.
If its Celotex, then your after PL3025, their range seems to be cheaper than other direct equivelants at present. ie: BG Knauf or Kingspan.
If your not requiring to adhere to a spec, then a real cheapy is the BG Thermailine Basic range ( EPS backed)
Is it going through building control if so the battens may be seen as a cold bridge and wont get passed unless you celotex over the top.
thanks for replies. have used the basic thermaline before but thought they were shite as the boards are never flat, they always have a slight bow in them. No building control involved so will probably just batten and celotex as nowhere round me seems to stock any kind of insulated plasterboard
many thanks
