internal corner trowel
i use a 103 degree mt drywall internal they are not very good when new but if you wear them in there good i use when i flatten the first coat and then everytime i trowel up i allways put i lilittle plaster on it before i start using it i dony use a brush on the internals at all only the internel trowel.
do i have to do anything to my angle trowel like bend the corners in a bit or file the corners round. cheers
i cut the corners round wiv tin snips on mine then only use it on second coat after flat to shape the corner in,after wet i just lightly brush corner in wiv very thin brush seems to work fine.
never used one for 30 years if your confident at working wet corners buy yourself a decent sach brush, its a peice of gear u dont really need, it can cause alot of problems for a learner
they have used those types of corner trowels for ever in the states as opposed to twitchers and they always run there corners in first this way ir spleys the mud out on the board and then when you skim up no lines hope this helps as it works
here we go gents....this is the way to plaster sorry if you think im being big headed, ( i am but im f**k**g good so i can be)........1st coat approx 2mm thick lay on as smooth as poss, get a trimmed up pointy 1inch brush and paint out corners, then  flatern 1st coat, lay second coat approx 1mm thick, get same 1inch brush wet and brush in corners , flattern down , wet trowel only minimum water as it will dull work only use enough to lubricate trowel, then use a 90 internal trowel ( twitcher) on corners, then  wait a while ( depending on time of year ) probably around10 to 15 miuns  before dry trowel and again if neccesary get a bit of muck on tip of twitcher and wipe down edges again, if u have to do this make sure you dry trowel out corners. If u use a twitcher prperly you can hit bigger hits instead of opposite hits which are slower and limiting. If i use a 2 man team we can hit 2 coats on an average room 12 by 12  dry trowel the lot by 11 to 123 oclock and start on next room ...no bullshit....this is the way to plaster consistantly with a finish that is second to non....on any background surface
if your not laying on board  and only old plaster etc then pva 3 to 1 mix to seal then 4 to 1 for a tack coat once seal coat is dry..if on artex then a good seal or maybe a few..........but if on polycell paints overboard and to be honest you should realy on artex too ....but...
This is the word and believe in it gents......cause their words of wisdom...told u i was big headed...but i can hit 100m in a day on me jack jones ....again no s**t www.jpplasterers.com
what the f**k you using a brush in the angle for your not a painter thats what the internals for
i use them just before the second and third trowel ......keep youre angles a tidy ass poss and idealy use them just before the third trowel it should pick up so youre not leaving the lines ..........there like skimming trowels mate dont try bending them it'll make them worse either sand the edges down or wait for them to sharpen naturally
grand u old c**t, smoOths internal quickly and effieciently....but use a twicher right at the end , the 1 incher is used to smooth but only a` quick wipe...but yes its a bit moody. but give a fecking fantatic clean edge...at least i dont use a sponge lol....hope your well nobby..and your as busy as me mate...times are tough around our way mate.. seen a few go under aLREADY..BUT ONLY THE s**t ONES...
yeah....... r u serious about that post phippsy333
Did i read the post wrong? Dont think it sayed how do you plaster and sound like a t**t about it.
sounds like ur a 1 coat wonder man? thats never good..have u ever been bk 2 paint ur 1 coat skim 100% its wavey in the light.
i do alot of barns...big hits...2 on the board each hit..each hit 30 odd m,, 3 hits a day in summer...thus 100m ish.........why what the problem.....penis envy?
never been a 1 coat wonder boys..if it aint perfect i hit it a 3rd time if needed which aint often......you might think this is bull..but it aint sorry boys........some are good ...other are just better..i dont do rendering...floor screeds...or anything else all i do is lathe plaster/ or modern material internal plastering...oh and the od bit of dry lining and basement tanking.........this aint a piss take......i do like hurting myself but as i say say i dont always do 100m hits in a day......if i did i wouldnt have an arm ...i subby out the painting and they love me because there is never ever any sanding or tiger stripes..im a perfectionist and have been told so by many builders and developers....ive never been a 1 coat wonder as i think their c**ts.....my works up there as an advertisement of me and my buisness..as i say thoses who have worked with me know this to be true....you might think im shitty you but i aint ..for a change...cause i dont pull legs about my work....and sorry f**k im late for me job so im off see ya
oh and grantyboy........its said not sayed...about how to use a twitcher..ie an internal trowel so i put it in context on when u should use it and how...wasnt being a t**t just telling you how..sorry if i came across like it...its just thats how your supposed to use it....bellend.....no need to get rude eh especially when im give advice on how to get quicker and get the perfect finish.........but u can abuse if u want.......as i say penis envy maybe
yes grand i am still busy at mo..but wont count me chicken just yet ..got 3 neew builds in jan and working till next wednesday tghen having time off for kids , still working on that thatched house from 1602 till then ...fecking had enough of it , but hey its money.......hope your well mate xx
ps boys...im a raving piss taker...please please dont take me to serious........love to stir a pot to see what comes to the top...just a little twisted.......im right about the techniques tho lol
