Internal solid wall insulation
FreeD
Anyone know which product from which company is the best for refurbishment jobs i.e minimum loss of space and U-value 0.35W/m2K? Cost not an issue.
Whatever size celotex they use in cavities these days will be good enough even a bit more than necessary for .35
you will need 50mm phenolic min as the boys have said. if you use ground battens or similar you will have cold spots so u may not get .35 overall but you could dab and fix insulated boards all round for full coverage
think your looking at 80mm cellotex with the 25mm air gap to hit .33 (refurb requirement, works out same as a cold roof) theres a calculator on the cellotex website, just bang in your wall/roof construction and it gives you a spec for whatever u value youre trying to hit...
