Bruce Willis said:Ive used some. Cant remember the name though. It came with plastic plugs that you fixed it to the wall with. TIP Unless you get enough fixings in it the sheet has too much movement in it. Obvious I know! I dry lined over it and it held really well. It was for a huge cellar and also in an office basement. Worked a treat. Sorry though I cant remember the name of the stuff. It looked like a darleks lower body. Loads of raised circles .
Oh really :madmonk said:i was in the G** bar first lol
madmonk said:the bubbles go against the wall an the mesh side outwards then its plugged with big plastic plugs which are wrapped with like black rubber seal then tapped in its overlapped at least 4inch with a run of rubber down the laps to seal it you can dab it and bond it out also but your suppose to dab ontop of the plugs if you can
nelly said:You know that shlt you nail on with the plastic nail things for damp.
Bond as in coat of bonding or hardwall etc
has anyone used it and is it okay?
Thats what we did when the new concrete slab went in but it was a bas**rd gettin the stuff behind coz if you let go it would coil backmadmonk said:realy your suppose to do the floor in it aswell which is lapped up the wall300mm then the wall membrane runs behind so any damp/water runs down the wall under the floor into a sump but you have got to seal it all with the black sticky rubber othrwise ther is no point
Bruce Willis said:Thats what we did when the new concrete slab went in but it was a bas**rd gettin the stuff behind coz if you let go it would coil backmadmonk said:realy your suppose to do the floor in it aswell which is lapped up the wall300mm then the wall membrane runs behind so any damp/water runs down the wall under the floor into a sump but you have got to seal it all with the black sticky rubber othrwise ther is no point![]()
i know bruce its a barsteward to roll out its quite stiff oooooh did i just say that lolBruce Willis said:Thats what we did when the new concrete slab went in but it was a bas**rd gettin the stuff behind coz if you let go it would coil backmadmonk said:realy your suppose to do the floor in it aswell which is lapped up the wall300mm then the wall membrane runs behind so any damp/water runs down the wall under the floor into a sump but you have got to seal it all with the black sticky rubber othrwise ther is no point![]()
nelly said:Ive dabbed on it before and it was w@nk, the walls were moving afterwards.
I was asuured by the installers this wouldnt happen but it did, and to be honest Im even more sceptical about bonding on it.
Thats spot on . Theres even screw wholes down the centre of the plugs so you can fix them. BUT IF YOU MISS!barryed said:the best way i have found is to scrtew it up with the screws in a line at 40cm centres then batton boaed and skim. You only need the basic membrane for that as well. YTou get no movement that way the screw holes are in the plugs think they take size 8 screws
What I found was if the dabs landed on a nail (plastic fixing) it was okay but most of them didnt.flynnyman said:nelly said:Ive dabbed on it before and it was w@nk, the walls were moving afterwards.
exactly the same the wall was movin all over.
barryed said:Surely there cant be to much difference between a 2x1 batton with a 9.5 mm board on than bonding it out
