k mix
they might be pushing it as the same or as good as or whatever but its not the same pal. Krend told me not to use it at full depth in one coat form, they said scratch with it or dub with it, also for laying block. the merchants round trafford park are pushing Kmix as cheaper and the same etc so we dont shop there now, plus were getting OCR even cheaper than before and better price than kmix wich is not as good.
they have uf base for OCR so that tells you the answer? if kmix was so good they could get rid of UF base
Crap Gary, spits like funk when you spray and it seems like a lightweight s&c, standard base is nice stuff though.
it is nice to spray. ive used it on a Durisol system on internal,but i used it as a final coat, just rubbed it up.
its similiar to spray like parexbric, they only problem with parexbric, with it being lime based you wait an age to rule it.
We used the comrend a few tears ago ( i think from memory its the one they produce for both hand and machine,also has no silicon in it) . Seem to remember it being very short and a pig to work with.and not a patch on the lurverly creamy Weber. We are though now, 9 months into using a machine and our methods of working renders have become much more diverse.
I wish we had brought a machine years ago.....
