Is k rend general purpose mortar the same as Weber ocr render
And does it get applied the same
Ocr can be applied in 1 coat application can the k rend or does that need scratch coat 1st then top coat after thanks
K Rend gp is recommended 2 coats. Use as you would traditional render. Although there are some that have applied in one and had no problems.
In my opinion OCR is worlds better.
