K Rend watermarks
Stuartb
Hello everyone ‍♂️,
I was wondering if anyone has come across an issue where after K Rend has been used it appears like the attached photos when it’s wet? Or what they might think the issues are?
Thanks in advance.
In the first pic its water running down the drip bead to the lowest point. The second pic it is water running of the top as it has no drip.
It will eventually stain, worst case go green.
But if it has not yet stained, get it sealed with a sealer. K Rend makes one and you cant tell its on. Two coats wet on wet and its watery to put on. Just make sure it doesn’t go on glass or paving. You will see it when it rains otherwise.
Water will all ways hit render and go s**t ,thing is the modon render are make for hot country like f**k**g India were theys f**k all rain
This is a bad build detail ! If the finish was render brick or glass it would have issues ! Modern renders are great if used correctly
Rain water is just running down the surface of the render as there is no sufficient overhang protecting it.
