You know your stuff mate :RpS_thumbup:Krend ft is very fine finish because its mostly grain the others have more fines with fewer grits but a larger grit size so with weber you get a more random surface with small Pitts at random intervals but close enough to give a nice uniformed finish.
Ft is more uniformed and does not have any deep pitt as such more like a sand fine finish also probably the reason it's horrible to spread.
Krend wp is a pitted finish.
You don't get the glass specs in weber that you get in krend either so the sparkle in the finish won't be there.
Thats easy krend is **** weber is good.
