doing this job next week going to base coat it first so less mixing on the ft as per photo they have projected the brickwork a good 20mm
so above the door an window what is the best bead a normal drip bead sat on the base coat or do they do a 20mm bead thanks
Use drips where you can keep to the dpc if it runs into the brick just stop and start it again. If you have a brick course all the way round then its up to you. I tend to still use a bead tho
