essexandy
The Lake Governor
Any of you lads work on Knauf board regularly?
We've just a bungalow completely tacked using Knauf board instead of the usual BG gear. The setting went exceptionally well with a lovely even suction. Didn't use a drop of water to trowel up right through the place. Three easy trowels and walls and ceilings looked great.
Question is was this largely down to the Knauf board or just coincidence?
Oh one moan about the Knauf board @Runwithscissors , the foil comes way to far past the ends of the foil backed boards and then hangs down between the boards looking tatty.
