krend etc
spunky
of all you lads that hand apply what do you do?.........do you go through the lot with one coat or second coat as youre going?..........also what sort of thicknesses are you doing per coat?
i always second coated as i was going and as for thicknesses it depended on what size beads we were using if they was only 10mm beads then a bit thinner then if they was 15mm, but as a rule a good first coat then a good second coat making sure you lay it on thick enough so as not to scrape back to the first coat
firs coat whacked on second past the beads an rule it dont know what thickness they go on at tho, dont do too much of it tho
