spunky
ive had a look at a job and he wants mono over spar ......i was going to brush it down hack off the lose render s/c it back level then hpx or rendaid the lot with a full mesh ???.....does this sound right ? also if you go over over any existing stuff with a base coat do you need to pretreat it with anything?.........also ;D. ;D ;D...........is it true that if you over render more than 30% of a property you need to get the cavity insulated or use an insulated render system ?
