Krend patch
S a plastering
got a patch of krend to do it's about 400mmby400mm it's where a boiler flue use to be was was going to grind it nice an square what's best to do just put it on proud all way round never really tried to blend any in any info on this cheers
Cut out neatly and mask the surround. Then apply leaving proud to scrape back level. The orange tape is good.
I never cut neatly I sort of zig zag the opening thus to take your eye off any blend. But yep mask around it. Try and find out what time of year they did it as even though it might be the same colour different scrape times alter the colour of finish.
If you have got any put a coat of sbr around the cut thickness making sure none is on the surface.
