Personally i think bedding beads over the base coat is a waste of time, why not bed them on whilst you are basecoating thus leaving you will all the prep work done instead of having to go over it again to do the beads
Because if you set one bead while you're base coating and it goes off and you come to put another bead ontop or below or whatever you do if you stick them as you go you can't adjust the bead you've already set And **** using 19 mm beads if I was doing that I'd nail the f**k**s on and put my base coat on after and lose a bit of depth
