lights..
  • Thread starter Thread starter bigsegs
  • Start date Start date
B
bigsegs
Guest
do you always find yerself workin in your own shadow when your using pod lights or tripods?
anyone ever tried usin them strap on head lights that sparkys use??
segsworld...population 1. :D
yeh, but everytime you turn round you get blinded and spend the next ten minutes trowelling over a big green blob...and the bulbs last ten minutes...and they get unreasonably hot... :P
i use the touch cool lights which arnt as powerfull as the ones, u use. so it dosnt cast much of a shadow and also dosnt blind u or burn u.
the lights i use are the equiverlent to 150 watt each, sometimes they could do with being a little bit brighter. 8-)
back in the day i did a job mate and i overestimated it which ran through till seven at night, i had no work light and insisted on the leccy being off so i had to finish it off by torch light ;D .............never try to do three sets in domestic work!!!!
i had the customer following me around .................ha ha he must have seen some beuty misses ;D
segs world population ........ 2
I've tried a head torch and it don't work.
Wherever you're looking the light is shining directly at it so you can't see any shadows.
A good one would be a double head torch with one either side of your head so it'll pick out misses and hollows.
Also seem to remember doing a ceiling one evening and danny had to turn leccy off for summink.
Couldn't stop. had to trowel it in the dark! Up a ladder. The fun!!!!!
