hi there
I only started plastering about a year ago but I work for a company that just does period properties. So 70% of my work so far has been lime and hair. I understand what you guys are saying about being crap. Panels falling off every 5 min, stings like a b***h when you get it in your eyes. Having said this, its not a particularly difficult skill once youve got going. We get all our lime from jewsons, gets dropped off in ton bags straight to the job ready mixed. You can get it in buckets but its more economical to get it in bags. One thing to remember is that you cant mix the base coat up with a mixing drill as it takes all the hairs out. Although I havent got years of experience a few notes to remember are:
-Make sure if you are going onto laths that you put lots of preasure on the base coat so that the lime is forced between the laths, in total we put it on about 7mm thick.
-Remember that lime takes donkeys years to go off. We try to leave it atleast a week between putting base coat on and top coat.
-With period propertys cutstomers tend to be collect antiques so make sure you take precautions, as lime is a pain to remove. Ccurrent job involves knocking up outside then carrying in buckets up scaffold and through the window. After last incident of dropping a trug full onto the customers "extremely expensive" victorian waredrobe.
Best of luck mate. An dont worry bout trowelling base coats up. Just slapppp it on. Hope this helps,
Rob
