Limelite high impact blah de blah
Lobo
Hi everyone,
Newbie on here so just introducing myself with a couple of questions on the above.
We have a flood damaged property with the likelihood of future flooding around every 5 years the property gets about 2 foot of water through it so finish coat needs to withstand this.
We've hacked off to 1 metre all the old finish and back to brick. Sbr slurry coated and base coated with strong sharp sand mix.
We have a painted finish on the walls above this. Was considering using the limelite to finish the new render with so was wondering whether to skim whole wall or blend into existing paint finish if that can be done with this product.
Alternatively thought of using multi then finish with a hydroscopic paint to keep the wet away from the multi.
I'd really appreciate some feed back if anyone found themselves in a similar situation.
Thanks in advance
Don't render , restore and patch original brickwork with lime , nice bespoke wood second fix
If you're stuck with blocks go for the industrial look
Ha ha, yes thank you for the pearls of wisdom. We are carrying out the work for a client.
Thankfully flooding isnt an issue where I live.
Anyone had real experience of the product?
